Hey, just recently i got a mac thinking it would be best for editing movies.
I have problems finding information and programs for macs. So need your professional help guys.
my source footage is dv-ntsc , i put that into toast vcd option, it converts to mpg and burns.
i end up with very bad quality.
Can anybody tell me what fit n crop options do on toast when converting to mpg? Why is my vcd so bad?
maybe i need to chance source to vcd mpeg frame size? or use a different source and export with different codec. i dont have a clue but my friend made a vcd on pc and it looks alright. little bit blocks now and then which i dont mind. Someone help please make me happy[/code]
Originally Posted by vcdhowto -
Also, since you're dropping your file onto Toast, Toast only makes standard VCDs, and VCD is bad quality when compared to SVCD, DVD and DV. Your best option to retain your DV's quality is to make a DVD.
I think that even compared with other methods of making standard VCDs, Toast is one of the worst ways. Try using ffmpegX, or mediapipe (burn with Toast).
toast's VCD codec is crap..i don't know how they get away with it.
try encoding your mpeg in another application first, then burning it in toast. that way you can adjust the bitrate and other settings to make it the quality that you want it. good luck!
Toast "An error has occurred recompressing the video"
By trevytrev in forum MacReplies: 12Last Post: 25th Feb 2015, 16:47 -
"Live" picture effect - pictures end up "filmized"
By ANOther1676 in forum Software PlayingReplies: 10Last Post: 14th Oct 2011, 11:59 -
movie to mpg for dvd by toast too large; "keep in" been ignored
By jboyd in forum ffmpegX general discussionReplies: 2Last Post: 11th Oct 2008, 13:26 -
Making a Toast "DVD Video" Disc
By albloom in forum MacReplies: 5Last Post: 22nd Apr 2008, 11:45 -
Video is "blocky" when capturing DV via firewire
By kongla in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 29th Jun 2007, 03:27
