I have this simple question and I am hoping for a simple answer...
I've looked around and tried some things, but just can't work it out.
I want to take selected chapters from several DVD's and combine them to one "best of" DVD-R. I preferably want to do the authoring with Pinnacle Studio 8.
I've used DVD Decrypter and SmartRipper to extract the .VOB's for the chapters I want. I know how to demux to .M2V and .AC3. But how do I combine them again to get the original .MPEG2???
I've tried TMPGEnc, with option "Mutiplex" under "MPEG-Tools", but this seems to re-encode somehow and the thus generated .MPG's seem to generate unknown errors in Sonic MyDVD and Pinnacle Studio 8.
I just can't seem to get the original .MPEG2 files with normal stereo sound and - if present - subtitels. I do not care much about the subtitels though.
My idea is that I do not have to re-encode, like with ReMPEG2, since I just want the original .MPEG2 file. With sound. That's all. Simple, isn't it???
Any suggestions, please?
Results 1 to 12 of 12
Originally Posted by Hoekie
you can use authoring programs to re-mux the ac3 and m2v=vob's... DVDmaestro is good program...
read guides in www.doom9.org
Zzzzzzzzzzz -
I know about other authoring software, but I prefer to use Adobe Premiere or Pinnacle Studio.
I just want to know how to extract the .MPEG2 "directly" from the .VOB!
Thanx anyway![/quote] -
Originally Posted by Adder_78
I am looking for MPEG2 with sound! -
Originally Posted by BJ_M
O.K., if so, what should I use to get the best quality then? -
Dvd Decrypter
if you want re-encode then you should use CCE
Zzzzzzzzz -
For some reason, when multiplexing .M2V & .AC3, the latter won't load.
I know I succeded it once, ripping with DVD Decrypter. Later I tried Smartripper, had to install ASPI, and now both seem to give bad .AC3 files. At least, That is what TMPGenc tells me... -
when loading ac3 files into tmpgenc muxer , make sure you use the drop down list and slect ac3 file type or they will not load ...
never mind the "you MUST use CCE" statements thrown about ... believe me, though slower, you can get superb results from tmpgenc. -
Doesn't work either, but I found something else.
I now use DVD2DVDr to do the same as I did with DVD Decrypter and SmartRipper. This gives .M2V and .AC3 I can multiplex in TMPGEnc. I only get the "packets cause buffer underflow" warning, but as I understand, that's meaningless. Anyway, I've managed to author a perfect DVD-r with the output!
I've used Sonic MyDVD to edit the as above described obtained .MPG's.
Works perfect!
Thanx for all the help! -
I use smartripper to extract the vob for each chapter then use dvdx to convert vob to any mpeg I desire at any bitrate or resolution.
Originally Posted by Crispy
I just want to extract the .M2V movie and .AC3 sound from the .VOB to subsequently multiplex them to .MPG (MPEG2, that is!) without any loss of orignal quality, whatsoever. For further authoring to a new DVDr.
Converting means changing something, and imho you can never get more quality then the original!
How to import MPEG2-TS to Adobe Premier? How to convert MPEG2-TS to MKV? :)
By farzad in forum EditingReplies: 19Last Post: 29th Feb 2012, 16:25 -
DVD to VOB/MPeg2
By Westport in forum MacReplies: 6Last Post: 9th Oct 2011, 20:41 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
DVD (VOB) files to mpeg2
By maxamillion in forum DVD RippingReplies: 7Last Post: 17th Dec 2008, 23:37 -
Video Stutter / Skip when coverting from DVD to VOB / MPEG2 file
By afs_nj in forum MacReplies: 2Last Post: 13th Jul 2007, 15:39
