I have looked through all the ratings of the capture cards. I wanna know what the best one is at a decent price. I wanna be able to capture videos into SVCD format, and then be able to also have it capture at set times. I want something that has awesome quality and sound..... any suggestions ???
A cheap option is the Kworld DVD maker TV or, its clone, the Provideo 256T.
It has a hardware codec for MPEG (Cirrus Logic CS92210) but it looks like the audio is compressed in software.
The video capture quality is very good.
The audio quality is good, but not excellent.
The best feature is its price. I got mine for just $135 bucks.
If you get the Kworld DVD maker TV you will need to download and install Provideo 256T drivers because they are a lot better and provide a couple of new features.
For a well done review go to the following link: http://www.iln.com.au/pv256.html
Otto. -
Are you looking for analog or digital video capture. You might check out what Pinnacle Systems has. They sell the Studio AV. It comes with an analog capture board and a copy of their Studio 8 software that will let you burn VCDs.
Rick Popko
Pinnacle Systems
Whats a good analog to DV card with great quality?
By Onceler2 in forum Capturing and VCRReplies: 12Last Post: 2nd Dec 2009, 03:30 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 11:45 -
Whats the best Capture Card around $350
By azza6 in forum Capturing and VCRReplies: 7Last Post: 27th Jul 2008, 16:20 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
