I downloaded the new version but its no longer supporting the VOB file specially in audio part.... do you know why?
my old version works like a charm...
Smartripper -> Tmpgenc
Thanks![]()
I know what you mean, I had the same thing crop up a while back with TMPGEnc. I'm not so sure it's entirely to do with TMPGEnc tho, may have something with codecs or something similar, seem to remember it happened to mine after was messing with new codecs.
Anyway I think I was having audio sync problems when I did it like that so I gave up and used dvd2avi as the frameserver instead, only take a min or two (if you don't downmix etc. do that stuff later using external tools via TMPGEnc environmental settings - it's quicker and better quality)
TmpgEnc 4 XPress Question
By VEBouto in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jul 2009, 20:36 -
TMPGENC question
By triumph2004 in forum Newbie / General discussionsReplies: 0Last Post: 23rd Aug 2008, 00:21 -
TMPGEnc question.
By Hal05154 in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2007, 09:20 -
TMPGEnc Question
By dafoe in forum EditingReplies: 5Last Post: 12th Oct 2007, 05:38 -
TMPGEnc XPress 4 Question
By Anakin in forum DVD RippingReplies: 1Last Post: 25th Aug 2007, 00:08
