Using All In Wonder Radeon to record live TV I get 30 secs of footage which then gets stuck in a stutter loop for the rest of the file. This happens with MPEG1, MPEG2 and AVI about 90 percent of the time.
Also TV reception with the card produces a picture which intermitently shifts between 2 different brightness levels. Really annoying and unwatchable/unrecordable.
Any ideas anyone?
System:
1200 Athlon
256 MB Ram
60 GB Maxtor 1200rpm HD
Gigabyte motherboard
it's macrovision. (copy protection) search for it. there's some programs that help in some instances but generally the only way around it is an external hardware box to remove it
Thanx Patrick. But is macrovision used on live analogue TV broadcasts (reception via antenna)? This brightness flickering thing makes even watching TV a pain. And is it responsible for my inability to capture more than 30 secs of TV?
might just be bad reception. is it an amplified antenna? i don't know, the only channels that use macrovision are MTV, HBO, cinemax, etc, and a few random satellite channels. broadcast tv shouldn't. maybe it's just getting fooled into thinking it's there though.
if the capture loops it's macrovision. if the brightness varies it could be that or just a bad AGC (auto gain control)
<font size=-1>[ This Message was edited by: patrickm on 2001-07-04 21:40:54 ]</font>
ATI 7500 AIW capture problems
By saoneg in forum Capturing and VCRReplies: 8Last Post: 6th Mar 2008, 05:11 -
Problems installing AIW drivers
By Ddanrr in forum Capturing and VCRReplies: 3Last Post: 10th Oct 2007, 20:14 -
Anyone using MMC with X800XL VIVO-only (no TV tuner or AIW) for capture?
By palouse in forum Capturing and VCRReplies: 4Last Post: 15th Aug 2007, 02:28 -
Problems with Pal-60 capture using ATI AIW 2006 PCI express Radion X1300
By DB83 in forum Capturing and VCRReplies: 2Last Post: 6th Aug 2007, 16:49 -
Asus My Cinema P7131 Hybrid Capture Card - No Audio or Digital Reception
By Duchess in forum LinuxReplies: 10Last Post: 5th Jul 2007, 06:55
