Ok, I'm converting my DV tapes to PAL format and putting them on DVD for my friend who lives in Spain. I don't have a settop PAL DVD player, so I can't test them here. However, when I test it on the computer, the image looks stretched. Is this because I'm playing it on the computer or is this how it will look on his TV? Is there a way to maintain the original aspect ration by adding black bars or the like? I've tried playing with the settings on TMPGEnc under Video Arrange Method, but it doesn't seem to have any effect, at least when viewed on the computer.
Thanks!
-Andrew
don't worry about how it looks on the computer.. the set-top DVD player will stretch the picture to full size and it will appear correctly. (how do you think 480 x 480 = square SVCDs appear correctly on a TV screen?)
the only reason it would look "stretched" on the TV screen is if you stretch widescreen 16:9 video to fill a 4:3 screen.
you're not working with widescreen (as far as i know) so you should be ok..Swim with me
And we'll escape
All the trouble
Of the present age
Finally free
NTSC to mpeg4 : how to keep the aspect ratio
By mathmax in forum Video ConversionReplies: 35Last Post: 2nd Apr 2012, 06:54 -
Converting from Mini DV - Problem with Aspect Ratio PAL Widescreen
By Videonisse in forum Capturing and VCRReplies: 9Last Post: 30th Jun 2009, 17:01 -
PAL SVCD - Optimal resolution for preserved aspect ratio?
By Gew in forum Authoring (VCD/SVCD)Replies: 7Last Post: 27th Feb 2009, 14:25 -
PAL aspect ratio 2.35 format to 16:9 NTSC
By chowa in forum Video ConversionReplies: 7Last Post: 2nd Feb 2008, 17:16
