Results 1 to 10 of 10
  1. I have ripped to an AVI using vidomi
    i have deleted all other vob files etc so im left with only the avi, the sound is way too quiet
    the file size is currently 699MB and i dont want it to go any higher than around 720mb
    how do i up the volume? (could you please step by step me?)
    thanx for any help
    vamps
    Rock On
  2. Open the AVI with virtualdub. Under audio select "full processing mode." There is a volume menu under there that will increase or decrease the volume. Tried that yet?
  3. yup tried that but makes the file turn out to be 1.3 gig
    Rock On
  4. well dose that make the volume louder if so have you tried to reencode it to a smaller size? like to mpeg.
  5. yup makes the sound louder but if i encode to mpeg (which i persoanlly dislike ) the quality turns to shit...
    Rock On
  6. When you upped the volume, did you compress it too? If you just up the volume in full processing mode, I think virtualdub increases the volume, but writes in the track uncompressed hence the huge size increase.
    Jul 2002
    Salem, OR
    Adjusting the volume has no affect the size of the file. As Sicamous suggested, you probably saved the file without checking the compression options.
  8. what compression should i use fpr the audio using virtual dub?
    Rock On
    Jul 2002
    Salem, OR
    Whichever one you would like that works on your system. If you will only be watching the video on a computer, you might as well use MP3. If the video is using a Divx codec, you could also use a Divx WMA codec (if you have that on your system).
  10. mm..when i try that i use direct stream copy for the video and the wma 2 compression for the audio...the file still comes out to 1.3 gig..
    or if i try using wma 1 it comes up unable to use that compression (or something to that effect)
    Rock On
