i have i file which i think may br xvid and when i open it only the audio plays how can i fix this
download a tool like Gspot (link available in the tools section of this website) that will tell you what codec was used to encode the video on the file you are trying to play. I suspect you are missing the proper codec. If you already have the codec installed, try another video using the same codec and see if that works, if not, then reinstall the codec, if the other video does work, then the video itself may be corrupt or improperly encoded.
Good Luck,
Prospero
downloaded video wont play in my dvd player
By KingRich70 in forum Newbie / General discussionsReplies: 17Last Post: 10th Jan 2011, 18:52 -
can anyone help me figure out why certain files wont play on media player
By DaLoKi in forum Newbie / General discussionsReplies: 1Last Post: 13th Dec 2010, 14:44 -
AVI wont play on standalone player, need to convert to what
By haubmi in forum Video ConversionReplies: 13Last Post: 10th Mar 2009, 13:58 -
.mvi clip wont play in Windows Media Player
By NP11073 in forum Newbie / General discussionsReplies: 0Last Post: 29th Nov 2008, 07:52 -
wmv file wont play nor convert
By excitezone in forum Newbie / General discussionsReplies: 7Last Post: 18th Dec 2007, 12:56
