I want to try to convert some divx files I have to xsvcd but I dont know where to find a calculator to find out what bitrates to use with the different resolutions I have. Obviously I cant use the svcd calculator because of the different resolutions. Can I use the xvcd calculator?
You can use a svcd/xvcd calculator. The resolution does not matter when you calculate the bitrate. (if you have a high resolution remember that you should not use a too low bitrate though)
Mpg : Mpeg video size and bitrate calculation
By Bonie81 in forum ProgrammingReplies: 2Last Post: 21st Jun 2011, 23:38 -
Need some info on bitrate calculation
By heman28 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 19:18 -
video bitrate calculation
By nivek_nayr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 12th Feb 2008, 22:30 -
overscan calculation
By cd090580 in forum Newbie / General discussionsReplies: 2Last Post: 2nd Jan 2008, 08:14 -
Newbie needs bitrate calculation advice to convert my 1st PAL to NTSC
By queen_anne in forum Video ConversionReplies: 35Last Post: 20th May 2007, 22:48
