Results 1 to 9 of 9
  1. I downloaded goldmember and while i like the widescreen format the bars on this are huge on my TV.Is there a way to reduce them without losing quality,and i am using the standard vcd template in TMPGE.
    Thanx
    Tom
  2. If you change the size of the bars the whole picture gets stretched and it looks funny. Thats just the way widescreen movies look, And I dont know about you but I would rather have the bars than a weired stretched picture.
    Budapest, Hungary
    I just waana add, that widescreen movies are also broadcasted on tv sets.
    Of course the bars are there also, but not as thick. When I'm converting to svcd I usually trim some pixels from the right and left of the movie.
    I always aim for 16:9 aspect ratio, then when letterboxing I letterbox it to 4:3. This way I can get more "color" on the tv, but I get some information loss. Anyway I've burnt a lot of discs this way and usually the action is in the middle of the picture, and you wont miss anything, only get a better video to watch.
  4. can you please explain the method you get more color to your tv??
  5. Some people do like the widescreen versions better. check http://www.widescreen.org then see why it's better (sure, some people will still prefer full screen, yes)
  6. yes widescreen is the way i like my movies, just takes getting used to. the vhs mafia has brainwashed you into liking your movies with the sides cut off.
    -Beware of the n00b mafia-
    Budapest, Hungary
    I mean the the movie, under color. The black bars are black not coloured. ( of course you can add purple borders if you like)
    widescreen is for the movies. 99% of viewers have a 4:3 ( some 16:9)
    sets at home. To improve the quality of TV viewing at home you must concern using 16:9 as THE aspect ratio.
  8. i have understood, what you mean, by getting more color to your 4:3 tv. and thats exactly what i want to do.
    so i asked how you get some pixels of at the sides and so get 4:3 with more color. please explain.
  9. Originally Posted by mategal
    Explain the 16:9 thing to me why worry about it? Many movies are made in 2.35:1 and that is the way i leave them because that is how they were inteneded to be seen. So cutting from the side so you see 16:9 loses part of the movie but how does this improve the quality of tv viewing any more than any other form of widescreen
