My player doesn't seem to play NTSC Film VCD's correctly and if I encode at 29.96FPS the audio is out of sync. Do I use 3:2 Pulldown? How do I do this...the source is 23.97 fps. I am using TMPGenc. I have made succesful VCD's but I still consider myself a newbie who needs step by step instructions!
Thanks in advance,
Justin Ward
You need to convert your audio in Virtualdub to a wav. then use it as your audio source in TmPEGenc. Do a short five miute test to see where the audio sits in sync and thwn use Cooledit to add or subtract the difference to the sound. Its a bit of work but it works.
NTSC video with a film-like/PAL to NTSC conversion type of look that shouldn't
By Bix in forum RestorationReplies: 34Last Post: 8th Feb 2010, 15:17 -
Syncing Audio CD to Video of Concert (with possible PAL>NTSC conversion)
By ehmjay in forum MacReplies: 3Last Post: 7th Jul 2009, 21:31 -
Subtitles and NTSC -> PAL Video Conversion ?
By shotokan101 in forum SubtitleReplies: 14Last Post: 5th Jan 2009, 20:39 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 11:30 -
Video Freeze after Conversion to NTSC
By gcam in forum Newbie / General discussionsReplies: 6Last Post: 1st May 2008, 10:57
