I want to take files that I recorded with my replayTV (which I am told are in MPEG-2 format) and convert them to MPEG-1 so I can burn them to VCD. Please help!
Results 1 to 9 of 9
Chris Cheatwood
http://www.chris-place.com
http://www.geocities.com/newestmoviesencode/dvdvcd
you could try this , its faster than converting -
I don't have them in SVCD format.....they are mpeg2 files and I want them in mpeg1 format. Please HELP!!!!!
Chris Cheatwood
If they are mpeg2 files that are readable or playable on the computer, all you need to do is get ahold of TMPEGenc. and use that. Run the wizard select video cd NTSC clip them whatever you need to do, let it run and encode, when it gets done you will have a burnable mpeg1 file. I cap mpeg2 and do this all the time with good results. Oh , you have to select all files as type in order to see the mpeg2 files when browseing for file. at least on my sys. you do. there are also some very good how to's on this site enjoy reading? you can learn alot. I've gotten pretty good just by reading about problems others have had and tweaking my way around programs to good results. I'm back learning more recenlty got a big screen and now some of my stuff doesn't look great on a bigger screen, looked better than store bought vcd's on the 27" but now not so good. Time to go read and play. Hope it helps you.
TMPGEnc has a problem when I select the file. Says it cannot open it.
Does anyone had similiar problems...These files same from a replayTV unit.---------------------------------
Chris Cheatwood
If its an mpeg2 you will need some sort of mpeg2 decoder on your computer for tmpgenc to read them - install poweredvd or windvd.
you must have the full version of tmpgenc to do mpeg2 also. -
its not a encoder issue... ReplayTV files are different for some reason.
I have yet to find success on using TMPGEnc...
MPEG2VCR sucks at reencode.
anyone know how to use TMPGEnc with REplayTV Files? -
Try using DVD2AVI as mentioned here: http://www.planetreplay.com/phpBB2/viewtopic.php?t=968&postdays=0&postorder=asc&start=15
Gowry -
You could try the header trick:Originally Posted by clcheatw
http://www.vcdeasy.org/modules.php?name=_Guides&id=VcdTrick
Hope That Helps!!!
:P
How to convert just top/bot field of an interlaced mpeg-2 video to mpeg-1 ?
By vahid in forum Video ConversionReplies: 4Last Post: 19th Oct 2010, 03:26 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 08:30 -
convert VCD.DAT/MPEG to RMVb with dual channel audio
By newbievideohelp in forum Video ConversionReplies: 15Last Post: 7th Nov 2008, 00:42 -
Convert mpeg-4 to mpeg-1 with ffmpegx?
By CollinH in forum ffmpegX general discussionReplies: 2Last Post: 22nd Sep 2007, 23:36
