*new creator here!
I'm going to be buying a new DVD player and after reading all the info on some players only play some cd's created by some burners created with some software, I figured I'd just create my Snowboard Trip VCD and test it on DVD players to see if they're compatable with my gear... Thing I wanna know is how do I know if I've created one correctly?
I've followed the steps, used Nero, and got one... I read on here to change the .bat files to .wma and I could play it on my windows media player, I did that it worked fine... So does that mean I have a good VCD and if I find a player to play it things *should* work fine?
Thanks for the feedback.
Just do what I did....
Take your VCD into the store....and ask them to try and play it on different machines to see what works.
Check out the DVD compatability
http://www.vcdhelp.com/dvdplayers
Type in some of your possible choices to see reports from other owners."Today is only yesterdays tomorrow"
testing 321
By bendixG15 in forum TestReplies: 10Last Post: 26th Jan 2012, 06:36 -
testing
By Baldrick in forum TestReplies: 0Last Post: 16th Jan 2009, 18:46 -
Testing
By Cirone in forum TestReplies: 0Last Post: 9th Jan 2008, 12:43
