Does anyone know if there is a MPEG-3 Encoder? or MPEG-1 conversion to MEPG-3? If there is; is MPEG-3 better then MPEG-2? Thanks.
There is no MPEG-3. I believe there was supposed to be for a time, but they rolled the changes into MPEG-2. You have to jump to MPEG-4 if you want to move 'up the scale' from MPEG-2.
That said, MPEG-4 isn't necessarily better than MPEG-1 or 2. It is a newer codec, so more efficient and theoretically you can get the same quality picture at a lower bitrate than MPEG-2. MPEG-4 also provides for all sorts of multi-media encoding- more than just simple compressed audio and video. -
I think (i may be wrong) but mpeg 3 video is juist a high bitrate mpeg 2.
Baker -
"MPEG-3" was created for high sampling dimensions (resolution). Later it was merged into MPEG-2, now it is part of the MPEG-2 high 1440 level and the HDTV high level (1920*1080). Obviously there was no use for a separate MPEG-3 video compressionstandard.
Which one is has the best quality picture at a high resolutions; MPEG-1, MPEG-2 or MPEG-4? Thanks.
well mpeg2 can go to 4000x4000 and so can mpeg1 ... do you mean data rate instead ?
mpeg2 high def 1080p or i @ 50meg/s bit rate looks mighty good -- looks even better @ 118meg/s -
I have heard that DivX is a form of Mpeg4 or something along these lines, is this true?
The Hellsing family will purify this world...
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 19:14 -
which mpeg-2 encoder would you choose...
By deadrats in forum Video ConversionReplies: 28Last Post: 12th Nov 2009, 23:11 -
mpeg encoder for DSP
By mourya in forum ProgrammingReplies: 2Last Post: 31st Oct 2008, 12:28 -
DV to MPEG2 using Mpeg encoder
By neftv in forum Video ConversionReplies: 8Last Post: 16th Jul 2007, 07:39 -
The best DV AVI to MPEG-2 Encoder for me to use.
By leegutcher in forum Newbie / General discussionsReplies: 6Last Post: 7th Jul 2007, 08:54
