I couldnīt found the answer in the how to tab on the side.
Is there any way to make a "self bootable" vcd / svcd disc? (i.e. that reproduces automatically when you put them on the DVD player, like normal DVDs.)
I know that the parameters I found both in nero and in VCDeasy are specifically created for CDi player from philips, right?
Thank you
"You must be the change you wish to see in the world" - Gandhi
I think you can do it thru VCDEasy. Put autorun.inf and exe file into CD.
Sorry, I didnīt explain myself correctly.
I want that a (S)VCD autorun when I put it on my standalone DVD player. (A pionner DV-344)"You must be the change you wish to see in the world" - Gandhi -
I think that depends on your Standalone and not how its burned. Not sure though
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
Panasonic DMR-ES25 "creating" unusable disks
By imageplanet24 in forum DVD & Blu-ray RecordersReplies: 19Last Post: 8th Jul 2010, 08:51 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 10:30 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 05:45
