Apparently there is some size limitation in QT so that QT will not correctly play back files > 4GB (maybe just mpg's)? Does anyone know if this is a bug that Apple will fix, or is it a "feature"?
If I try to export a > 4GB mpg from QT to something like a DV stream, will it export correctly?
-- rockinsage
yep, apple did that with quicktime to keep people from doing exactly what we are trying to do. what you can do is rip the dvd file or what ever file your trying to reencode into peices that are 2GB or less, or use extractor to split it into pieces and then quicktime will play them. if you are reencoding an mpeg2 file then you can use extractor to rejion them into one.
i know there is a ~4 gig limitation bug, but i don't know if apple intentionally put it in to prevent us from doing things, do you have any actual proof that apple did it on purpose?
As below, so above and beyond, I imagine
drawn outside the lines of reason.
Push the envelope. Watch it bend.
Over thinking, over analyzing separates the body from the mind. Withering my intuition leaving all these opportunities behind.
How to play Quicktime with PNG codec on my videoplayer (not quicktime)
By Henkie in forum Software PlayingReplies: 0Last Post: 11th Nov 2011, 03:50 -
An AVStoDVD non-starter (file-system limitation)
By Seeker47 in forum Video ConversionReplies: 9Last Post: 24th Nov 2010, 10:53 -
TV output with SANYO VPC-FH1 limitation
By pjandreu in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 5th Jun 2010, 18:29 -
Noob:Philips 5990 WMV resolution limitation??
By peggypwr1 in forum Newbie / General discussionsReplies: 6Last Post: 27th Feb 2009, 02:28 -
Is There A File Size Limitation to Convert .ts?
By toddon14th in forum Newbie / General discussionsReplies: 6Last Post: 16th Jun 2008, 23:04
