I wanna encode an DivX movie and i have to extract the audio stream to *.wav before using Tmpeg to bring it in SVCD format.
But i have a problem. Yesterday i encoded my first Xvid movie to VCD and i have to recognize that after installing Xvid no other DivX movies were played correctly. Then i installed DivX again and then i have to see that Xvid movies were no longer played correctly...
Whats the prob???
I have also a prob with Virtual Dub. It says under File Information that under Compression: Unknown (tag 2000)
Does anyone know which codec is meant?
Originally Posted by zedriq
Whats the problem? -
You have AC3 for sound, most XviD movies use it to save the space and get a great quality. It isn't a problem if you can hear it anyway - most likely it is rendered by DirectShow filters that come with Nimo Codec Pack. If you really need the codec itself, look for AC3 on the web. In the future you might need to look at this guide if you ever want to convert it to (S)VCD.
Regards. -
No, it isnīt like this. Right now, i can watch DivX movies w/o any probs, but Xvid movies have green chunks in it. Xvid has been installed with Nimo Codec Pack, but all Xvid movies are green chunked...
Whats the prob...??? -
The green chunk problem might be caused by 2 things:
1) incorrect or unstable version of XviD codec installed: don't use the XviD codec that comes with Nimo Codec Pack, download the latest stable binary of XviD from here
2) bad/corrupt frames while downloading: fix the bad frames or download another copy
Good Luck. -
Originally Posted by 0 kewl
Can somebody help me please
Divx/Xvid problem in Virtualdub (not mod)
By leeqk in forum Newbie / General discussionsReplies: 14Last Post: 11th Apr 2010, 01:18 -
AVI.net a confusing problem : using DivX instead of XVID
By Alterego in forum DVD RippingReplies: 5Last Post: 17th Jun 2009, 12:39 -
Xvid and Divx playback problem on TV set
By herbapou in forum Media Center PC / MediaCentersReplies: 3Last Post: 7th Sep 2008, 12:17 -
Vob to Xvid in autoGK or Divx Converter problem
By arcangel14563 in forum DVD RippingReplies: 1Last Post: 19th Nov 2007, 17:11 -
Problem with Divx/Xvid with Winamp and Virtualdub
By mekuka_pinasem in forum Software PlayingReplies: 5Last Post: 1st Aug 2007, 11:41
