  1. i set up a dvd file to reencode and when i try to start the process i get an applescript error that reads as follows:
    File not open with write permission. (-61)
    whats up?
    Jun 2001
    Silver Spring, MD USA
    Don't use the installer inside the AfroPic .sit file. Just drag out the other file with the little afro pick icon.
  3. i haven't used the installer, i was just using the icon inside the folder. any other ideas?
    7th layer of hell
    copy afropic into ANYWHERE on your computer, just get it off the disc image, if you dont take it off the disc image it will NOT work EVER (for current releases) u will always get that error running it off the disc image, so just copy it into your applications folder or somethin, doesnt matter where u copy it to, just cant be on the image when running.
    As below, so above and beyond, I imagine
    drawn outside the lines of reason.
    Push the envelope. Watch it bend.
    Over thinking, over analyzing separates the body from the mind. Withering my intuition leaving all these opportunities behind.
  5. ahhhh. that makes sense. thank you bilestyle!
    Jun 2001
    I'm perplexed. Didn't I say that?
  7. Not really in so many words. But thanks anyway.
