Using ReelDVD 3.03 and the Explorer window is greyed out. I can see all the other windows just fine, but anything with a path is not showing up on the screen. Same situation when I go to create DVD, the paths are grey. I end up importing assests by dragging from Wndows Explorer. That works, however, the create DVD option needs it's own explorer window. Anyone see this error?
YEP!
and its pissing me the **** off!
it claimed to be a problem with GEAR software
yet, i dont recall having any gear software installed
mitch -
GOT it!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!
PTxSCP.ocx
that file in the sonic/reeldvd directory... register it!!
there was a newer version in my windows/system32 directory... which ofcourse didnt get overwritten by the sonic installation of reeldvd
and its broken
prob not sonics fault... go blame plasmatech
its a nice shell active X
mitch -
Mitch,
I've just installed ReelDVD and had the exact same problem so I was interested to see your posting.
How exactly do I register the file?
Thanks -
go to the directory where the file is
open a cmd box
regsvr32 PTxSCP.ocx
thats it...
mitch -
Many thanks!
Will registering PTxSCP.ocx in the ReelDVD directory screw up or affect the other version of PTxSCP.ocx in the windows/system32 directory? Do I run any risk of affecting other programs?
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 08:58 -
DVD Shrink Error: Programing Error, exception occurred
By lapetite_66 in forum DVD RippingReplies: 5Last Post: 2nd Jun 2010, 15:59 -
ReelDVD 2.5 crashes when I import PSD file for a menu
By Cygnus111 in forum Authoring (DVD)Replies: 2Last Post: 3rd Apr 2010, 07:21 -
Error with Xvid4PSP when converting MKV to AVI (VirtualDub Error)
By Peter25 in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2009, 18:10 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
