    Oct 2002
    INdiana
    I have the Ulead DVD movie factory and wanted to customize the DVDR i make by adding a personal image/picture to the beginning of it sorta like an FBI warning where it is shown for a few seconds then disappears. I have no Mpeg picture, only jpeg. Is there a convertor program? or what do i need to do to get a personalized image to a DVDR movie?
  2. You will need and mpeg encoder, to convert the jpeg to mpeg files.
    you can look on this site or search
    www.ezdvdadvisor.com
    or a search engine
    Michael
    Learn to create DVDs the Ezway
    DVD Related Question Post them at
    www.EzDVDAdvisor.com
    DVD Developers Community
  3. Член BJ_M's Avatar
    Jul 2002
    Canada
    all you need is TMPGenc which can convert your jpeg perfect to mpeg2 ..
    just make a wav file (anything) the lenth of the clip you want to play (say 7 seconds) and load wav and load jpeg and hit convert ..
  4. Sound like a good way to do digital still.
    Does TMPGenc rescale the jpeg to full screen ?
  5. Член BJ_M's Avatar
    Jul 2002
    Canada
    yes it can -- but select display full screen .. or if you dont want it full screen just use adv tools and set it how you want ..
