Can some advise how I can boost the video quality on a vcd using tmpge without using the svcd option. If some one has a predefined templete that would be great if you could email it to me. dlb@talk21.com
Also, what is best when encoding - High quality slow or Motion Search fast.
Thanks in advance.
dlb.
Does the source video also look substandard?
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
you wanna stick with standard VCD 2.0 right??? how about upping the bitrate and making an xVCD, but that would be non-compliant.
motion search accuracy should always be set to high quality (slow), don't set it for any lower.
How Can I Improve my video quality
By legend10 in forum Newbie / General discussionsReplies: 36Last Post: 23rd Feb 2012, 14:01 -
Improve video quality [HELP]
By v1rto in forum Newbie / General discussionsReplies: 8Last Post: 13th Jul 2011, 08:46 -
How to improve the quality of the video
By kemo1000 in forum Video Streaming DownloadingReplies: 2Last Post: 24th Apr 2011, 15:36 -
how to improve video quality?
By George2 in forum ProgrammingReplies: 1Last Post: 19th May 2009, 02:07 -
Low quality video on high resolution screen, improve video quality?
By Nitrius in forum Software PlayingReplies: 4Last Post: 29th Dec 2008, 13:38
