Hi!
I got DVD Studio Pro. And it installs also the mpeg2 encoder ...
I'm trying to reencode m2v-videos so that the will fit on a DVD-R.
I read that its possible to generate a pic with the movie size 720x567 (PAL), ... import it into Quicktime, ... open the M2v original and paste it into the Pic-File, so that Quicktime will export and reencode the movie file to m2v again.
But ... if I try to open a m2v file (no matter if the source is ripped by OSeX or its already reencoded by ffmpgX) Quicktime does not recognize the m2v-file in the open dialog ...... whats wrong??
What do I need so that Quicktime will read my m2v files????
Thanx a lot for assistance!
Markus
If you are just trying to use the files in DVDSP without reencoding, and you get the "bad file format" error, then you need to fix them with MoreMissingTools. In this case, you don't need to open them in Quicktime.
Help with m2v files
By Mikhel in forum Video ConversionReplies: 0Last Post: 19th Feb 2012, 06:22 -
BD player Sony BDP-BX57 not recognizing .srt files from external USB memory
By arjuna1980 in forum SubtitleReplies: 0Last Post: 7th Jun 2011, 13:07 -
Problems with computer recognizing camcorder
By serrac in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 23rd Jul 2009, 02:31 -
AGK and Video-redo not recognizing my HDTV files...?
By OrangeTTT in forum Video ConversionReplies: 17Last Post: 10th Dec 2008, 01:34 -
problems Muxing M2V and Aiff files to MPEG2
By bbaddorf in forum ffmpegX general discussionReplies: 4Last Post: 18th Jun 2007, 15:14
