  1. i am sorry to bother you with my stupid questions..
    i have downloaded a mpg file, and when i play it it goes really slow and freezes evry few seconds and goes back to just being slow.
    is there a way to fix it?
    p.s - i looked in the faq and couldn't find an answer. the nimo pack didn't seem to help either.
  2. providing other mpgs play OK on your system I would suggest that the mpg you downloaded is corrupt, if you are getting audio and visual then the correct codecs are installed so it sounds to be a dodgy mpg
  3. you could run the mpeg through virtualdub to scan for any errors
  4. thank you all for the help
