Hi there,
I'm trying to convert DVD to VCD. I used sefy's newby guide. I used Smartripper, then DVD2AVI then TMPGEnc. Everything is fine until i hit start in TMPGEnc then after a while, i get a "read error at XXXXXXXX of module TMPGEnc.exe with XXXXXXXX."
I'll start over and i'll get the same error at a different place. anyone know any fixes for this?
thanks.
Hi as no-one has replied I thought I would, the only thing I can think of is have you unzipped TMPGenc and DVD2AVI in the same folder?
i think i did. but in case i didn't, should i uninstall then re-unzip after placing in the same folders?
That certainly might help, I suggest you get TMPGENc 2.59, as the single zip comes with both TMPGEnc and the VFP
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
thanks for replying.
i recently got it to work without that error popping up wihtout having to uninstall and re-unzip in the same folder.
Sefy, if you're still tuning in, from your guide, you have two links to download tmpgenc, one plain and one with the vf thingy. both links seem to take me to the same place and i downloaded both but they seem to be the same program. are they different?
thanks -
One of the links is for the TMPGEnc and the other for TMPGEnc Plus.
In the past, the TMPGEnc Plus download area didn't have the VFP download.
Now that they include it within the same package, it will need a bit of an update, thanks for the concern 8)Email me for faster replies!
Best Regards,
Sefy Levy,
Read error with TMPGEnc
By MasterScreech in forum Authoring (VCD/SVCD)Replies: 2Last Post: 24th Jun 2010, 20:08 -
Unhandled exception error mencoder convert opendivx video - How to solve?
By melaos in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2009, 05:43 -
TMPGEnc Read Error
By koberulz in forum Video ConversionReplies: 0Last Post: 6th Nov 2008, 22:44 -
Disk read error....
By rubberman in forum ComputerReplies: 12Last Post: 12th Feb 2008, 15:06 -
MTR can't read DVD... READ ERROR: Can't Open IFO.
By strathq in forum MacReplies: 16Last Post: 17th Jun 2007, 00:04
