Hello!
How do i add subtitles to a existing mpeg file and burn to a CD?
Are you aiming for VCD or SVCD?
/Mats -
There are a few guides under EDIT, left! The reason I asked, was because SVCD supports selectable subtitles, whereas VCD doesn't, so they have to be added before encoding (or during reencoding, resulting in quality loss).
/Mats -
how do you add sub BEFORE encoding??
my process is:
rip dvd into mpeg using EazyVCD, fast and pretty good quality
use 'subrip' to rip the subtitle
use 'virtual dub' to put the sub to the mpeg and serve it to 'tmpegenc'
DONE! mpeg w/ subtitle
then burn it using vcdeasy
any easier method w/ fast and good quality mpeg?? -
If you however have a VCD format MPEG, run this thru VirtualDub to add the subs, and then once again encode it in TMPGEnc, you're gonna loose quality.
/Mats
Load external subtile on sony DVP-NS628P
By Mil@d in forum DVD & Blu-ray PlayersReplies: 6Last Post: 11th Mar 2010, 00:55 -
Subtile track problem
By ppeterr in forum Newbie / General discussionsReplies: 0Last Post: 1st Jun 2009, 13:45 -
Problem with viewing persian subtile
By sina1362 in forum SubtitleReplies: 5Last Post: 9th Sep 2008, 22:50 -
add/burn srt sub into avi
By volam in forum SubtitleReplies: 2Last Post: 24th Aug 2008, 04:48 -
Subtile on movies
By mutras in forum Newbie / General discussionsReplies: 17Last Post: 15th Jul 2007, 18:56
