  1. here's my XML:
    <?xml version="1.0"?>
    <!DOCTYPE videocd PUBLIC "-//GNU//DTD VideoCD//EN" "http://www.gnu.org/software/vcdimager/videocd.dtd">
    <videocd xmlns="http://www.gnu.org/software/vcdimager/1.0/" class="vcd" version="2.0">
    <info>
    <album-id></album-id>
    <volume-count>1</volume-count>
    <volume-number>1</volume-number>
    <restriction>0</restriction>
    </info>
    <pvd>
    <volume-id>GENEVA</volume-id>
    <system-id>CD-RTOS CD-BRIDGE</system-id>
    <application-id>CDI/CDI_VCD.APP;1</application-id>
    <preparer-id>GNU VCDIMAGER 0.7.7 CYGWIN/I586</preparer-id>
    <publisher-id>TSCV07r3</publisher-id>
    </pvd>
    <filesystem>
    <folder>
    <name>CDI</name>
    <file src="C:\vcd\CDI\cdi_imag.rtf" format="mixed">
    <name>CDI_IMAG.RTF</name>
    </file>
    <file src="C:\vcd\CDI\cdi_text.fnt">
    <name>CDI_TEXT.FNT</name>
    </file>
    <file src="C:\vcd\CDI\cdi_vcd.app">
    <name>CDI_VCD.APP</name>
    </file>
    </folder>
    </filesystem>
    <sequence-items>
    <sequence-item src="C:\geneva\Final\0. The Introduction\theintro.mpg" id="intro"/>
    <sequence-item src="C:\geneva\Final\title.mpg" id="menu-0"/>
    <sequence-item src="C:\geneva\Final\chapters1.mpg" id="menu-1"/>
    <sequence-item src="C:\geneva\Final\1. Visiting Nick & Pre Drive Activites\nickdrive.mpg" id="sequence-1">
    <default-entry id="entry1-0"/>
    </sequence-item>
    <sequence-item src="C:\geneva\Final\2. The Road Trip\trip.mpg" id="sequence-2">
    <default-entry id="entry2-0"/>
    </sequence-item>
    </sequence-items>
    <pbc>
    <selection id="intro-0">
    <next ref="selection-m1-0"/>
    <timeout ref="selection-m1-0"/>
    <wait>0</wait>
    <loop jump-timing="delayed">1</loop>
    <play-item ref="intro"/>
    </selection>
    <selection id="smenu-0">
    <bsn>1</bsn>
    <prev ref="intro-0"/>
    <next ref="smenu-1"/>
    <return ref="endlist"/>
    <default ref="smenu-1"/>
    <timeout ref="smenu-0"/>
    <wait>0</wait>
    <loop jump-timing="immediate">1</loop>
    <play-item ref="menu-0"/>
    <select ref="smenu-1"/>
    <select ref="smenu-0"/>
    </selection>
    <selection id="smenu-1">
    <bsn>1</bsn>
    <prev ref="smenu-0"/>
    <return ref="smenu-0"/>
    <default ref="selection-m1-0"/>
    <timeout ref="smenu-1"/>
    <wait>0</wait>
    <play-item ref="menu-1"/>
    <select ref="selection-m1-0"/>
    <select ref="selection-m2-0"/>
    </selection>
    <selection id="selection-m1-0">
    <bsn>1</bsn>
    <prev ref="smenu-1"/>
    <return ref="smenu-1"/>
    <wait>0</wait>
    <play-item ref="sequence-1"/>
    </selection>
    <selection id="selection-m2-0">
    <bsn>1</bsn>
    <wait>0</wait>
    <play-item ref="sequence-2"/>
    </selection>
    <endlist id="endlist"/>
    </pbc>
    </videocd>
    Now everytime I try to build I get: Starting VCDxBuild process...
    parsing file `C:\vcd\TSCV.xml' failed
    VCDxBuild finished
    What am I doin wrong?
  2. There is a new version out that has alot of the bugs fixed plus Ttool has 2 guides out for the latest version. You can download it at his site.
