Hi guys i convetd dvds to divx useing the following dvdx my settings are divx 502 for video and mp3 128 kb/sec but on playback the sound is fine but the picture is a green scrambled mess. has anyone else had this problem? cheers.
Sounds like you downloaded a patched version of DivX Pro. I hear alot warez version of DivX Pro get all screwed up. Try going to divx.com and downloading just regular divx.
Hope that solves your problems
Don't download warez!! -
something is definatly wrong. is the file watchable before you do the encoding? what prog are you using to encode with? vdub? try uninstalling every thing divx-clean registry and reinstall.
experiment with a small 1 or 2 minute clip. start with a basic encode. like 1 pass - all defaut settings- lame mp3 audio. and go from there. and then you can go from there adding one filter or tweak at a time.
you may want to check you resolution also. with 5.02 i have had video not show at all with certain res'.
peace -
hi hoola_loop im useing dvdx 1.7 the picture looks fine while encodeing its only during playback. how do i clean the regestry? cheers
dv to divx problem
By anajat in forum Newbie / General discussionsReplies: 3Last Post: 10th Jul 2011, 20:27 -
H.264 - Divx..... problem !!!
By tjolle62 in forum Portable VideoReplies: 2Last Post: 25th Mar 2009, 17:45 -
Divx subtitle on DVD/Divx player Problem
By abo_shreek11 in forum SubtitleReplies: 4Last Post: 24th Mar 2008, 15:39 -
By abo_shreek11 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 8th Mar 2008, 04:41 -
DivX to DivX Convertion Problem
By Spiderm@n in forum Video ConversionReplies: 25Last Post: 4th Dec 2007, 06:15
