i ripped a couple backups before and they play fine. but i tried burning some .avi's i downloaded and they will not play in the player. it just says load and it freezes up. its like its not recognizing the disc. the cdrs are the same kind as the vcd that works.
any ideas
thanks
tuknrm
Results 1 to 9 of 9
Apex dropped VCD support a while back. You can check here for Apex specific help.. www.nerd-out.com
thats what weard it plays other vcds i have created in past just not the new ones. could i be doing something different or wrong?
I know this might be a dumb question, but you said you burned some avi's. Did you convert them to mpeg vcd first?
Something has to be different in your conversion process or maybe you are using differet media for the new stuff??
its the same media. im using the instructions off vcdhelp.com this time. i lost the old instructions that i had good results with and cant find them
What programs are you using this time, which process from VCDHelp? You get a new burner? I have had too many problems lately with different drivers burning VCDs.
While on the subject anyone have any ideas as to why a Plextor will not read / write / or re-erase any RW’s after erased or written on other drives…I guess it seems to be picky right now. (Most updates firmware on all burners I use.)
some will play and some wont.
By kushy66 in forum Newbie / General discussionsReplies: 9Last Post: 22nd Aug 2011, 21:32 -
MKV DvdRip Xvid Downloads Play on WMP but wont play on my PVR
By dashas in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2011, 05:15 -
Help! Apex 5131 Will Not Play DVD
By NautTboy in forum DVD & Blu-ray PlayersReplies: 2Last Post: 24th Dec 2007, 11:33 -
I want to play VCDs on my laptop
By Michel-lyn in forum Software PlayingReplies: 2Last Post: 22nd Dec 2007, 10:38 -
I can not play some VCDs on my mechine. Can U help me ?
By wapw in forum Software PlayingReplies: 2Last Post: 21st Aug 2007, 11:46
