Hi. I recently tested out ripping a music video trying to make a test VCD. Everything went fine in the CD burning proccess, but for some reason, the disc wouldn't play in my DVD drive. It seemed like I did everything the guide I have (from dvdrippingguides.com) said to do, but it still didn't play. I then came back to my computer and tried it out in my DVD-ROM, and to my shock, it worked just fine! I could play the video in PowerDVD and everything! Anyone know why that is? To my best guess I can only assume that I'll need a DVD burner to write to a DVD-R in order for it to play in my normal DVD Player. Am I right? Or did I just miss something during the burning proccess that would have made the normal CD-R VCD play in my DVD player?
Results 1 to 9 of 9
it might be that your dvd player cannot play either cd-r, cd-rw, or vcd.
Yes, you can play VCDs (video recorded in standard CD-R) in *compatible* DVD player. Check your DVD manual to see if it's compatible. Mine's a Panasonic RV-31 and it plays DVD, DVD-R, DVD-RW, CD, CD-R, CD-RW and VCDs. It also plays VCDs with SVCD format (only with the header modified as a VCD). Cannot play Mini-DVD (DVD format recorded in a stardard CD-R) or standard SVCD.
Greetings from Brazil.
Marcos. -
Yes, looking at the manual, it's just that my DVD Player isn't compatible for CD-Rs
Thanks for the help though. At least I know I didn't do anything wrong or miss anything in making the disc itself. Oh well. There's still DVD-ROM for now
:P
TRY CD-RW,
I have a Sony 300? system/wdvd and it will not read any CD-R media I tried, but it will read and play VCD, audioCD, dtsaudio etc. on CD-RW media. There may be other players that can read rewriteable media but not CD-R.
J
E
JD tinkerer pushin' 60,
A real Life Enemy of the State, see Fed case #01-40080, Detroit.
Computers, Electronics, vintage Audio, Photography Film/digital/3D, N-Scale RR, ,
AKA the "Infamouse Joe Walker" ,Join the Navy & see (1/2) the world. -
Does anyone know if a standalone DVD player can be hacked, not to be multi region, but to play CDRs and, more importantly, VCDs and SVCDs? (I have an LG2280P and there are no cracks of any sort that I can find.) The manual says it can only play retail DVDs and audio CDs. Very frustrating. Looks like I may have to output to tape just to be able view footage on the TV, after all.
I'd guess the ability to read CD-R/RW is connected with what DVD reader the DVD is fitted with. So, it's a hardware thing and can't be hacked, if you aren't brave enough to replace the reader with some other CD-R capable reader!
It seems like a CD-RW is more like a manufactured CD than a CD-R, so if CD-R wont work, then CD-RW still might.
VCD/SVCD capability is more of a firmware thing, and might be possible to change with hack/firmware update.
/Mats
VCD cannot play in PC but can play in DVD player
By avatar123 in forum Authoring (VCD/SVCD)Replies: 28Last Post: 3rd Jan 2011, 17:32 -
Video from PC encoded and Burnt to VCD to Play on my DVD R Player
By dashas in forum Video ConversionReplies: 3Last Post: 16th Jul 2010, 22:15 -
just wondering - can normal dvd player hack to play hd-dvd
By chanra in forum Newbie / General discussionsReplies: 16Last Post: 12th May 2009, 23:00 -
GPX D1816SIL dvd player and I can not use it to play VCD disk.What should I
By nyankum in forum DVD & Blu-ray RecordersReplies: 2Last Post: 13th Jul 2008, 13:15 -
is possible to burn HD video to a DVD and play it on a normal DVD player?
By kozmo62 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 16th Jul 2007, 13:54
