does anyone know if the latest version of DVDdecryptor removes multiangles?
also, i tried ripping the T2 dvd w/ dvddecryptor, and the vobs are messed up (the vobs weren't decrypted correctly) and dvddecryptor doesn't have an option to have the key check every vob file rather than just once (let alone key check every cell ID)
anyone help?
for those of you that already ripped T2 ultimate edition, do any of you know if the DVD had a lot of multiangle in it?
i'm trying to rip the DVD using CladDVD and the ripped vob files r all smaller than the vobs files on the DVD....if there are alot of multiangle in the vobs...that would explain why the ripped vobs are smaller...but does anyone know ??? (maybe CladDVD can't rip T2 correctly either) -
i've ripped T2: Ultimate Edition DVD, i've had no problems, i've done it using DVD Decryptor 2.4 what is the problem you are having ?
oh and could you send me a private link or email with the link for v3.0 ?
_________________
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
<font size=-1>[ This Message was edited by: Sefy on 2001-08-26 14:29:08 ]</font> -
Sefy, yea..someone just told me T2 has a lot of multi-angles in it..turns out DVDdecryptor v3.0 has no support for multi-angles...(good thing sneakers didn't have multi-angles cuz i had to use it to rip the 1.00 gig vob file in it)
so DVDdecryptor v3.0 has no support for multi-angle removal (yet, i guess)
has anyone tried to rip T2 with smartripper..it has memory error when trying to open the dvd when i did it... -
Sefy, the place where i got mine is
ftp:\\dvd:dvd@lightninguk.dns2go.com
dunno if it still works...
(but i'm sure of it now as least the beta version of 3.0 doesn't have multi-angle support...the options menu is very basic) -
it's not working, but I see you are using DNS2Go too, i've started using it recently myself
if that program is upto 1mb, can you send it to my email ?
Best Regards,
Sefy Levy,
