  1. Whats the best way to get 2 films on 1 DVDR
    I have 2 films at about 2GB each
    Do I need to use some DVD Authoring software such as DVD Maestro to achieve this.
  2. if you can seperate the audio and video you should try using ifoedit95...
  3. Ifoedits dvd-author feature does not support two title sets yet.
    He would need to merge the two files first somehow.
  4. what kind of quality are you talking about, 2 movies on
    1 disc might not give you the results you want...like 2g
    movie at 2 hrs, video bit rate would have to be down
    under 2000, are they mpeg2 yet?if not have lots of fun
  5. Ulead DVD Moviefactory would do it with a menu to select between the movies. They are having a sale at www.ulead.com I believe.
    Panasonic DMR-ES45VS, keep those discs a burnin'
