I've been trying iuVCR (actually trying them all, but I want to cap in AVI). I can't seem to set the capture rate above 25 fps? I'm using NTSC-M (United States). I can pick any resolution I want, but not anything pas 25 fps.
any suggestions? I'm running an AverMedia mono card, with tricked out WDM drivers. I've had no issues at any resolution, just FPS. PowerVCR caps and 29.97, as does the internal software.
-Bryan
I never got this to work right either. Do a search for iuvcr in the forums, I know someone answered this issue a while back....
I found the Answer from October last year, Thanks to Shadow Runner!! There are to sets of color settings (Pal and NTSC) hence the 25 fps only. Unfortuantely having to YUV2's is confusing!
By default the program has four options when you choose the color format... it wants to use YUY2 color format, if you try to raise the framerate it doesn't work.
But if you change the color format to the other YUY2 THEN you can change the frame rate to 29.970 or higher.
See the four options are this....
YUY2
UYVY
YUY2
UYVY
Two of them let me change my fps to the correct NTSC 29.97fps while the other two use PAL 25fps.
So try them out and use the one's that work for you
Also if you ever go back in there it resets itself to the PAL 25fps.
But if you set to the one you want and dont go back in... it will use what you chose.
Have fun and goodluck!
A guy over at the Rage3D forums helped me figure this out so I give him credit if he reads this
NeVeRLiFt
_________________
Shadowrunner by trade... -
Finally Fixed!! The problem is the 'Tweaked Drivers' on the iuVCR site. Since it's a Euro Company, I can only assume there's a bug there for 25 FPS. I say this because even though I chose NTSC-M for my format, it did NOT properly choose the right country code (1 for USA) nor the right channel spacing (6 Mhz for USA). It defaulted to country code 61 and channel spacing of 1.
I replaced the drivers with the OEM drivers off the CD and I'm up and capping at 29.97 fps. I'm going to update the drivers off the Manufacturer site, but I don't foresee any problems.
Using Sony HDR-FX1 to Capture a Mini-DV @ 24 FPS
By foochuck in forum Capturing and VCRReplies: 3Last Post: 11th May 2011, 17:50 -
mixing 1280 x 720 29,97 fps and 1440 x 1080 25 fps in final cut
By perik in forum EditingReplies: 6Last Post: 17th Nov 2010, 22:42 -
Capture - Colors, Fps problem
By Ytek in forum Capturing and VCRReplies: 14Last Post: 1st May 2009, 08:30 -
1280x720 50 fps capture shows as 640x360 in media player
By bc55 in forum Media Center PC / MediaCentersReplies: 2Last Post: 28th Dec 2008, 14:57 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 19:17
