  1. I just tried to convert a divx file to VCD using TMPGEnc. I also converted the audio to .wav w/ audiodub. The first 40 minutes of the conversion went fine, but when i try to play back the file, the last 10 minutes of the file are just black, with no video or audio. I also noticed this while it was converting, but went back and played it again to make sure i was right. The original divx file doesn't have this problem. Does anyone know what happened? I hate to waste another 3 hours converting the file to VCD again if the same thing will happen again. Thanks a lot.
  2. Member Conquest10's Avatar
    Chicago, IL
    damn, how many times are you going to post this?
  3. only once in two different forums.
  4. Member Conquest10's Avatar
    Chicago, IL
    why not once on all the forums?
