Hi all. Sorry for the dumb question, but how can I rip from the dvd the translation? And then how do I attach it to the vcd?
thx
What do u mean by the tranlation? is it a second audio stream?
if so u can use DVD2AVI
open the IFO file in the DVD to know which stream is the audio u want it will look like this:
Stream[001] X=[[0xE0] Video NTSC 720x480] [] [] [] []
Stream[002] X=[[0x80] Audio English AC3(6Ch) 48kHz ] [] [] [] []
Stream[003] X=[[0x81] Audio Français AC3(6Ch) 48kHz ] [] [] [] []
Stream[004] X=[[0x20] Subtitle English ] [] [] [] []
Stream[005] X=[[0x21] Subtitle Español ] [] [] [] []
Stream[006] X=[[0x22] Subtitle Not Specified ] [] [] [] []
Stream[007] X=[[0x23] Subtitle Not Specified ] [] [] [] []
Stream[008] X=[[0x??] Others] [] [] [] []
if you want the english one then tell DVD2AVI to rip the 1st audio
if u want french then the 2nd
and save as wav -
sorry i forgot bout how to attach it to a VCD
i use HeadAC3he to encode my audio
if you open it select the ripped ac3 and select the ouput to b MP2
the settings for VCD audio are: 224kbs and Constant Birate. Save the .mp2.
U can use several programs to add the audio to an MPG (VCD) video, i would recommend you to use TMPGEnc
Subtitle Translation Feature
By frmys in forum SubtitleReplies: 5Last Post: 23rd Feb 2011, 02:14 -
Overlaying sound with translation over a movie.
By Maserati_Shamal in forum Newbie / General discussionsReplies: 5Last Post: 10th Jan 2010, 17:13 -
interpretation, I try to copy it because I enter the translation again
By krrish in forum Authoring (DVD)Replies: 3Last Post: 9th Sep 2008, 14:14 -
Recommended subtitle format for translation
By niko84 in forum SubtitleReplies: 11Last Post: 3rd Feb 2008, 18:35 -
Help with free AVI Trimmer GUI translation required
By DmitryV in forum Off topicReplies: 0Last Post: 19th Jul 2007, 03:49
