Hi all, in doing some reading on the site I've come across a couple of people that mentioned a bitrate minimum of 1600 when converting to SVCD. Is there a technical reason for this or is this just a suggested minimum for quality? I have just converted an AVI using a bitrate of 1387 (so I can fit a 6 part series on 3 CDs vs. 6 CDs), it is supposedly from a DVD rip and looks superb, would it be that much better with a much higher bitrate?
Yes, it is suggested to maintain a minimum quality level (I personally prefer even higher.) If you really think your 6-part series looks superb on 3 cds, then there is no real reason to re-encode at a higher bitrate.
What you could try is just to make a short test, cut (maybe five minutes) of a dark, and/or fast-action scene and encode at 1387 and at 1600+. Then burn both to the same SVCD and compare. This wouldn't take much time and would allow you to see the difference. The reason why I suggested making the cut of a dark scene, and/or fast action scene is that is the most likely place you may see a quality difference.
Want to make a video of a 'turning question mark'.. Winmorhp?
By spinningrom in forum Newbie / General discussionsReplies: 9Last Post: 18th Aug 2011, 10:20 -
Is there a possibility to...mark certain timespaces to maximize the bitrate
By waefwaeefwaefw in forum Video ConversionReplies: 3Last Post: 15th Jan 2009, 16:00 -
Why getting .mpg question mark?
By kevs in forum MacReplies: 0Last Post: 5th May 2008, 15:46 -
Question: how to add a moving mark to a video
By Nicholas76 in forum EditingReplies: 3Last Post: 24th Oct 2007, 12:26 -
TMPGenc won't allow bitrate to go below 1600??
By bebopdeluxe in forum Video ConversionReplies: 3Last Post: 10th Aug 2007, 19:49
