I have "Prolink Pixelview PlayTV HD" card based on Conexant CX23881 chip. It can capture up to 720x480 with WDM supported driver.
I would like to capture to make CVD (352x576) PAL, but I cannot captuer above ___x480.
What should I do, which resolution will be best to capture for my projects ?
Any other ideas. As far I know there isn't any tweaked drivers for that chip.
Japi
same problem here,
the chip itself supports full 768x576 capture, but i dont think Prolink has implimented that,
not sure its thats a hardware limitation or a driver limitation (i hope the latter)
the best cap resolution for PAL i have found is 1/2 288x384
i am trying to find a proggy that will support a higher res
iuVCR can do 640x480 but comes out blocky
AMD 64 X2 6000+ @3,000 Mhz (stock) | MSI K9N Ultra | Corsair Value/Kingston 6,144MB DDR 667 | 8800GT stock | 3710GB of storage | Powered by Mandriva 2009.1
Jabber: DaveQB@jabber.org.au
2.6.29.3-desktop-1mnb -
I'm not familiar with the software that comes with the Prolink Pixelview PlayTV HD card, but is there any chance, in there, it might allow you to do a "custom" capture profile. If so, you may be able to select the required resolution there. I have seen this kind of problem with the ATI MMC (the presets don't necessarily have the resolution I wanted) and I was able to go through "custom" and do it.
yeah good idea
but the software that came with i have hardly used, pretty average
i try and cap with iuVCR and AVI-IO
iuVCR limits me to 640x480 and AVI-io limits me to 352x288
i hope BTwincap like drivers are developed for this chipset soon
hmmm CXwincap, sounds nice huh ???
you can edit in the registry the resolution of th iuVCR
easy done,
jsut change the value to decimal, and change to the desired height and width
then open up iuVCR and save it as a preset, coz once you change it in iuVCR you cant get it back, (need to load preset)
EASYYY!!
and its great!!!AMD 64 X2 6000+ @3,000 Mhz (stock) | MSI K9N Ultra | Corsair Value/Kingston 6,144MB DDR 667 | 8800GT stock | 3710GB of storage | Powered by Mandriva 2009.1
I have the playTV HD card, I haven't tweaked any registry settings or anything like that, and I've been capturing 352x576 for my CVDs since I've had the card
I'm using VirtualVCR, and everything is fine. It lets you set custom capture res and doesn't complain when you choose 352x576, give it a go.
yeah i use Virtual VCR just exclusively now for capturing and watching TV.
VV is the best and it is free!!
big headache with capture card and new nxp chip
By mammo1789 in forum Capturing and VCRReplies: 5Last Post: 26th Jan 2012, 13:11 -
Chip Resetter - Will it reset "auto" 3rd party CIS Chip?
By RBYoshioka in forum MediaReplies: 10Last Post: 10th Nov 2009, 17:49 -
Hauppague WinTV-HVR-1600 vs Avermedia capture card with SAA7130 chip
By johnnyquid in forum Capturing and VCRReplies: 1Last Post: 23rd Mar 2008, 19:29 -
Which is better? Conexant CX23881 or Phillips TDA8290, TDA8275 Chip
By ffxdean in forum Capturing and VCRReplies: 3Last Post: 15th Jul 2007, 21:55 -
DTV/SDTV Captue Question
By drprocrastination in forum Newbie / General discussionsReplies: 2Last Post: 19th Jun 2007, 05:20
