I have loaded a .avi file in Virtual Dub 1.4.12 and when i come to save the .wav file I get the following error messages on certain files.
The requested audio compression is not compatible with the input format. Check the sample rate and channel count of the input match those of the requested format.
This does not occur with all .avi files but only on particular ones.
Can someone please direct me to a solution.
Anrasp
It sounds like AC3 for sound (unknown tag 2000). Use this guide to deal with it.
Regards. -
In fact you are right .. it's due to AC3. I have followed the steps and managed to create the .wav file. It took around 45 mins to create though (running Athlon 1800 XP).
Anrasp
problem with compression using virtual dub
By jpez1 in forum Video ConversionReplies: 4Last Post: 3rd Aug 2010, 14:24 -
Virtual Dub problem
By rocka in forum EditingReplies: 3Last Post: 2nd Jan 2009, 04:46 -
Virtual Dub Mod Saving Problem
By cdgfx84 in forum Video ConversionReplies: 2Last Post: 1st Sep 2008, 14:08 -
Simple Virtual Dub Problem...
By tetzy in forum EditingReplies: 2Last Post: 22nd Feb 2008, 20:49 -
Ripping DVD & Virtual Dub Problem...
By Chana1 in forum DVD RippingReplies: 7Last Post: 8th Jun 2007, 08:45
