I just wanted to know where in the nero directory structure for svcd should i put the mpeg file? and is mpeg, mpe, or mpg ok file formats for svcd?
I have had much better luck with VCD imager.. Then you use CDRwin to burn the bin/cue it makes... doesn't have the problems that Nero has (ff/rw)
Also, I have found that you should de-multiplex, then multiplex the file before you make the bin file... keeps it in sync..
just my expeirence.
Mike
Help with svcd 2 dvd
By tastybaker in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 11th Aug 2010, 10:30 -
Svcd 2 dvd
By GeordieDave in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Feb 2010, 11:05 -
svcd will not launch.
By hawkwind in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 17th Jan 2009, 19:09 -
Procoder SVCD
By kippard in forum Authoring (VCD/SVCD)Replies: 7Last Post: 17th Dec 2008, 11:51 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 07:18
