Hi,
I am trying to create SVCD from DV format. Here is what I do:
1. I capture my footage from DV camera using Ulead Video Studio 6.0. It captures into AVI file in DV-1 format.
2. Then I convert it to DV-2 format to be able to open it in VirtualDub (I also have MainConcept Codec installed).
3. To make SVCD using CCE (CinemaCraft) I have to resize it to 480x480 first. So, I frameserve it from VirtualDub to CCE.
The problem is that I can't open VDR file in CCE. It gives me an error: AviFileOpen error 0x80070485. I have tried to open VDR file by VirtualDub itself and it worked out. That makes me thing that something is wrong with CCE or something else.
I have been through many posting here and other forums but I couldn't figure out why CCE can't open VDR file in my case.
Thank you for the advice.
Alex.
hey! what CCE are you using? the only one with which you can do this is 2.50. You can't open .avs nor .vdr files with the others. This method takes too long n e ways, there is a better method to do it, very similar - less time consuming and same results.
I'm putting my own guide on the net with links to all the necesasry programs wil b there in about 30 mins
BUT will only b up for 24 hours...i don't wanna get fucked for sharing on html, it s very easy for ppl to find u
http://kickme.to/pirenaq -
soory that guide is about as useful as a fart in a hurricane
The electronic components of the power part adopted a lot of Rubycons.
Problem with opening AC3 in VirtualDub
By andy_blah in forum AudioReplies: 5Last Post: 6th Nov 2012, 16:25 -
Virtualdub opening H264 encoded file
By tvbear in forum EditingReplies: 0Last Post: 26th Dec 2011, 06:22 -
VirtualDub, problem with *.ts opening
By UMO in forum Newbie / General discussionsReplies: 0Last Post: 27th Feb 2010, 15:50 -
Problem opening Xvid movies in VirtualDub
By wombat4 in forum SubtitleReplies: 9Last Post: 24th Jun 2009, 09:23 -
Problem opening (.avs) file in virtualdub...
By dominator007 in forum DVD RippingReplies: 16Last Post: 19th Nov 2008, 10:53
