i tried to convert a few xvids with kewl0 settings and everything worked fine but the movie was too bright on my dvd player.does somebody know how to regulate the brightness when converting into vcd with tmpgenc![]()
If you use the Wizard: in the page 3/5 click on Other Settings, go to Advanced tab, tick Simple color correction box and double-click on it to access brightness controls.
If not using Wizard: access the same controls by pressing Setting button in the main window.
It will not affect TMPGEnc's ability to accept XviD AVIs.
Regards.
Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid file
By GrayStrickland in forum Video ConversionReplies: 4Last Post: 17th Aug 2012, 13:23 -
Converting Xvid to MPEG1(VCD)
By Ensign in forum Video ConversionReplies: 3Last Post: 18th Dec 2008, 16:00 -
best avi (divx/xvid) to cd-r (vcd) converter
By waefwaeefwaefw in forum Newbie / General discussionsReplies: 8Last Post: 15th Sep 2008, 13:36 -
How to convert VCD to Xvid (avi)
By nalika in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jan 2008, 17:51 -
Vista beginner needs help with video conversion! Xvid to VCD with subs
By Joakim_A in forum Video ConversionReplies: 2Last Post: 23rd Sep 2007, 03:59
