I am having a problem keeping the aspect ratio the same when converting to SVCD. Am using tmpgenc, and using the standard NTSC svcd template. When I convert with that, and I change the Aspect Ratio to 4:3, it comes out wrong. However, I can convert it to VCD with the same settings, (using the standard Video CD NTSC template) and the aspect ratio will be fine. Anyone know how to fix it? Thanks.
are you sure its not cuz svcd uses 480x480? it looks weird when converting but will play fine on a tv.
Aspect ratio problems, please help!
By phdutton in forum DVD RippingReplies: 21Last Post: 1st Sep 2011, 08:31 -
aspect ratio problems with makeMKV
By jadasneez in forum Newbie / General discussionsReplies: 4Last Post: 2nd Feb 2011, 17:24 -
By MarioB in forum Newbie / General discussionsReplies: 7Last Post: 2nd Jun 2009, 17:47 -
Aspect Ratio Problems
By Weapon-X in forum EditingReplies: 9Last Post: 9th Mar 2008, 13:38 -
Problems with Aspect Ratio
By qldaussie in forum Video ConversionReplies: 3Last Post: 10th Jan 2008, 12:53
