Hi, I tried to make a dvd by putting an mpeg file in toast but I wasted a blank dvd since it turned out to be a vcd. I calle Roxio and they told me that is not how to do it, that I had to make a video_ts folder in order to make a dvd. The thing is I do not know how to do it in both the programs. If any one can help i would be very grateful.
Import your Mpeg 2 file into Dvd Studio Pro. Select Add Track. Drag your .m2v file to the new Track tile. Click on graphical view window. Select startup action (this will be the name of your track tile) select it. Select File from the top of the DVD Sp menu. Select Build Disc. Select drive location you want to store your Audio_TS and Video_TS files. Hit the choose button.
Thanks, i am not sure that the file is an mpeg 2 file. I had an avi file and converted it to mpeg. That mpeg file can be turned into a vcd file through toas..so i do not know if it is mpeg 1 or 2. What is an .m2v file?
How to rip DVD's: Image File or VIDEO_TS-Folder
By flashandpan007 in forum DVD RippingReplies: 3Last Post: 9th Feb 2010, 11:08 -
Burning DVD with VIDEO_TS Folder
By bguguen in forum MacReplies: 7Last Post: 28th Jul 2009, 01:10 -
Avi->DVD no Video_TS folder
By gaikoku in forum ffmpegX general discussionReplies: 7Last Post: 13th Sep 2008, 13:11 -
Using Nero Ultra: How Do I Use Video_TS Folder ---> DVD
By MacPCConsultants in forum Newbie / General discussionsReplies: 6Last Post: 28th Nov 2007, 07:16 -
VLC - plays DVD from video_ts folder?
By qpskfec in forum Software PlayingReplies: 9Last Post: 21st Nov 2007, 14:38
