I purchased a Sony DRU-500A drive about 3 weeks ago. It has been great. I recently updated to firmware 1.0f which was supposed to increase the drives speed to 2x or 4x.
I have been using recordnow4.5, DVDdecriptor, and Gearpro(trial version). I have a trial version of nero,too.
I have not noticed any change in burn speed (it is still 1x). Does anyone have any suggestions? Thanks.
Badu![]()
well in order to burn ar 4x you need to buy 4x media. you are prob using 1x media and thats why you haven't seen a change...
I had Sony 500A also and update 1.0f and I used the cheaper ACCU disc and I can burn at 2x speed.
I used DVDdecriptor only (Set ISO read to read my DVD, then ISO write to write to blank DVD) of course my movie is less than 4.3GB.
I think Sony 500A is great. -
Just be aware. My Accu media (bought as 1x) showed in Nero that it is 2x, but real burning speed was jumping and final time corresponded to 1x burn speed. Please post result with real burning total time and amount of data that you burned.
Tried burning with DVD Decryptor, still 1x. Nero also 1x. Am using cheap Pinco DVD-R and Optodisk-RW disks. They work fine, but won't record at 2x.
Dumb question, do I somehow have to change settings on the DRU-500A or do I need 2x DVDs to get the drive to write at double speed?
Badu
Hi All,Originally Posted by donpedro
I just burned one DVD (Ritek - I bought around $0.85, I am out of ACCU) and I think this is write at 2x (needs 24 minutes). Here is the log:
I 18:41:51 Source File Size: 3,525,347,328 bytes
I 18:41:51 Destination Device: [1:1:0] SONY DVD RW DRU-500A 1.0f (F
I 18:41:51 Data Type: MODE1/2048
I 18:41:51 Write Mode: DVD
I 18:41:51 Write Speed: MAX
I 18:41:51 Test Mode: No
I 18:41:51 BURN-Proof: Enabled
I 18:41:52 Filling Buffer...
I 18:41:52 Writing LeadIn...
I 18:42:48 Writing Image...
I 19:04:12 Synchronising Cache...
I 19:05:35 Operation Successfully Completed! - Duration: 00:23:44
mguy97, it looks great.
Do you mind to contribute here ...
All 1x media that burns at 2x speed in Sony DRU-500A 1.0f
And also your Manufacturer ID, that you can get with ADVDInfo, will be very helfull. More info here http://www.vcdhelp.com/dvdmedia
/Sony DRU-190A problem
By Quadzilla in forum DVD & Blu-ray WritersReplies: 22Last Post: 7th May 2009, 15:10 -
Firewire External Enclosure for Sony DRU-500A. Help choose..
By donpedro in forum DVD & Blu-ray WritersReplies: 79Last Post: 25th May 2008, 12:52 -
Sony DRU 800A Problems burning??
By khronos000 in forum Newbie / General discussionsReplies: 4Last Post: 17th Sep 2007, 18:40 -
Sony DRU-810A question...
By bamabluebird in forum DVD & Blu-ray WritersReplies: 4Last Post: 10th Jul 2007, 11:21 -
Sony DVD RW DRU-830A
By bjswitz in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th May 2007, 09:41
