  1. I have been trying to burn a dvd using the following software...
    Either...
    Nero / PrassiPrimodvd / Easy CD 5.3 Platinum
    However, assuming I'm doing everything right PRE-BURN, the media seems to be disliked by my dvd player. I have never burnt dvd-r before (I am using a panasonic 310 dvd-ram), and having read that cyberhome 528's were ok with dvd-r, i bought 10 bulkpaq generation 4, 2 speed dvd-r. Howver, whenever I use them in my cyberhome dvd player, it just says bad disc. They work ok on my pc, or at least they seem to. Am I doing something obvioulsy wrong, or is the media completely useless?
    (Nero gave me errors when recording and Prassi seems to crash... so lately I have tried easy cd... but it still doens't work). AND I have updated the cyberhomes firmware.
    HELP. Thanks in advance,
    Paul
  2. And where You got idea Your DVD-RAM can write DVD-R or at least do it right?
  3. Where did I get the idea it could write dvd-r??? From the vcdhelp website. And if you're going to give usless repyls like that, then why bother? Jeez.
  4. DVD-RAM and DVD-R are two seperate discs! I own a 528 and I don't think they play DVDR's at all.
  5. Member marvel2020's Avatar
    Mar 2001
    Vorlon Home World
    energy80s wrote.....
    Sorry m8 but your wrong, The Cyberhome ADL-528 plays DVD-r's no problem because i have backed up over 30 DVD's onto DVDr's using PRASSI PRIMO DVD to burn them.
    And they all play fine on My Cyberhome ADL-528.
    As for DVD-RAM disc's, i would suggest that you not backup DVD's onto these disc's, instead buy yourself some DVD-r's and then back up your DVD's.
    Like some said, the 2 formats are totally different with DVD-r being the most compatible with Stand alone DVD players.
    One other thing update your Firmware on your Cyberhome to 10.01.
  6. The DVD-Ram drive burns either dvd-ram or dvd-r. I have been trying to use dvd-r. And it still doesn't work, it just says bad disc on the player. Oh... and I have updated the firmware. Still no luck.
    Paul
  7. Member marvel2020's Avatar
    Mar 2001
    Vorlon Home World
    Just as a matter of interest what proggy are you using to burn them ?
    EDIT:
    I see from your post your using Prassi Primo, like me
    Are you choosing the right options in that??.
    Here's a guide to using Prassi..
    http://www.harkcom.demon.co.uk/cyber-pages/writing-dvd.htm
    You'll see my name mentioned in that
