I’ve been backing up my DVDs to VCD for some time now. Just use two bits of software. DVD2AVI and TMPGEnc. I’ve tried playing around with the Aspect Ratio settings in TMPGEnc so that the play back on VCD is the same size window as the original DVD.
Can anyone point me in the right direction please?
Results 1 to 10 of 10
Under settings-advanced-video arrange method, you need to select full screen (keep aspect ratio)
What are you selecting as the aspect ratio for the source
I had this problem when copying anamorphic DVDs. I was clipping off the black bands to maximize the bit rate that went into the movie (I'm told this doesn't help much). When you do this you change the aspect ratio of the movie. Don't clip the frames and leave the aspect ratio 4:3 in the Video tab (if you are watching on a regular TV) and under the advanced tab, set the Source ratio as 16:9 and the aspect ratio to 'full screen (keep aspect ratio)' like the previous poster suggested.
Morloc -
Sorry "What are you selecting as the aspect ratio for the source"
I had the source aspect ratio set to 4:3 625 lines (PAL, 704x576)
Aspect Ratio
By jackowens in forum Video ConversionReplies: 2Last Post: 18th Mar 2009, 18:40 -
Aspect Ratio
By kolias in forum Newbie / General discussionsReplies: 5Last Post: 5th Jan 2008, 09:28 -
aspect ratio help
By thecrock in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jan 2008, 14:41 -
what is aspect ratio?
By mai_hnf in forum Authoring (VCD/SVCD)Replies: 3Last Post: 29th Sep 2007, 23:29 -
Aspect Ratio's
By AndySpring in forum Newbie / General discussionsReplies: 7Last Post: 23rd May 2007, 13:55
I new it was easy! Cheers!
