I forgot where I read the guide for burning up to 800 MB zip file to a 700 MB CD in mode 2 (ie svcd). Does anyone have a link or the guide here?
Thanks!
But think twice, before You do it. And then do not do. Mode 2 is suitable only for files with their own error correction.
as the poster says - you can do it but he suggests its not a good idea ..
Hi.
BJ's response is not the one I read about. the instructions involved renaming the desired file with a BIN extenstion (?maybe) and then burning a SVCD from the bin cue image. I have forgotten all the little details of it, especially how to create the Cue file.
In any case, thanks BJ. I'll try that.
I understand that this turns off error correction however, this is not my company's financial data that I'm trying to fit on one cd. =o)
It's a 3.2 gb Mpeg2 file that I'd like to get off my HD. I've already used bbmpeg to split it into separate 796 MB Mpeg2 files and then vcdimagergui to create the bin cue files but I'd like to keep the movie in one piece by using zip to split into 800 mb zip files.
asfbinwin1.8.2.903.zip contains wrong file
By asfbinwin in forum EditingReplies: 4Last Post: 28th Apr 2012, 22:41 -
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 13:21 -
.ISO zip file
By nodollas in forum DVD RippingReplies: 5Last Post: 10th Feb 2010, 18:07 -
How to relocate Zip File (Buck?)
By Tobias0815 in forum ffmpegX general discussionReplies: 1Last Post: 29th Jun 2008, 04:35 -
Obtaining the LG5000.zip file
By aliciavinc in forum DVD & Blu-ray PlayersReplies: 1Last Post: 8th Nov 2007, 05:58
