Is it possible to burn with dvd-r discs and make it dvd+r if your burner is only a dvd+r burner. I noticed they are cheaper discs.
where can i get the cheapest media that will work?
Nope.
a DVDR disc have a ID applied to that would make the Burner
refuse to burn to it if it is not the right format.
Second, -R and +R are not pre-formated the same way.
2X DVD-R cost the same as 2.4X DVD+R,
about $2 each at regular stores such as Bestbuy and CompUSA.
Samsung DVD-HR753 DVD and HDD recorder rejected all my blank DVD
By undangltn in forum DVD & Blu-ray RecordersReplies: 1Last Post: 14th Mar 2010, 12:34 -
DVD Recorder/VCR With No Tuner - Link to Broken Tunered DVD Recorder
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 1Last Post: 23rd Dec 2008, 02:05 -
Will a DVD-Recorder to DVD-Recorder copy lose quality?
By blackmetal in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jan 2008, 04:54 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 17:59 -
Toshiba RD-KX50 DVD Recorder / HDD Recorder
By Kinddomaker in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jul 2007, 21:19
