Nero Isn't recognizing my burner. Keeps trying to burn image on HD... Tried to auto-detect with no luck.... NTI CD Maker is doing the same. All other burning software operates correctly. Please give suggestions.![]()
I am having exactly the same problem, I had the original version but wanted to install it on another machine but it is tied to the cdrw that it was bought with, I downloaded the update from the nero website and it did recognise my drive, but stated that I needed to repurchase the full version to use it?!
You will need to purchase a full version of Nero from Ahead software. Once you purchase it you can then use their serial number to unlock the software to recognize your drive.
Have you tried RECORDER | CHOOSE RECORDER ? Silly question but it wasn't mentioned that you did.
Originally Posted by FoxGarrison
I would suggest contacting Ahead, but their tech support is rather poor. I've been waiting about 8 weeks for a reply to my problem (This problem actually - but with usb cd-rw).
W7 not recognizing camcorder.
By stanl in forum Capturing and VCRReplies: 1Last Post: 12th Dec 2010, 20:08 -
Nero Won't see my DVD Burner !!! HEP ME HEP ME!!!
By THE_oldguy in forum DVD & Blu-ray WritersReplies: 14Last Post: 24th Dec 2009, 11:07 -
Nero 8 not recognizing DVD burner
By JCWBobC in forum Authoring (DVD)Replies: 11Last Post: 14th Dec 2009, 22:20 -
Nero Burner in new version of s2d version5
By couzican in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 3rd Jul 2007, 18:50 -
Newbie's DVD burner isn't recognizing DVDs as burnable (Both DVD+/-R)
By OhGodHelpMe in forum Newbie / General discussionsReplies: 9Last Post: 30th May 2007, 08:48
