I haven't changed any hardware, but am now getting audio drift while capturing to avi(huffy). I don't get any dropped frames, (which would probably help, since the audio gains on the video). It never used to do this. I am now using the Santa Cruz 4161 drivers, the ATI Catalyst 2.5 drivers, and MMC 7.7. I don't see a setting for keeping audio/video in sync. Turtle Beach said it was a clock issue between the SC and AIW, but it used to work perfectly. Anybody have any words of wisdom, before I reformat, and reinstall from scratch.
Try capturing with virtualdub, if it is a clock difference between the sound card and capture card that is causing the problem, virtualdub will drop the odd frame to maintain AV sync.
Well, I capture 480 x 480 avi, edit commercials, then Tmpgenc CBR fit to 800 MB.
I think that starting with MPEG, editing, and re-encoding would give me worse results.
I like MMC, it's easy to use and pretty automatic, but I'll give VD a try, but I'll need a VFW wrapper won't I? -
Depends on your operating system, the vfwwdm wrapper is built into xp, not sure about 2kOriginally Posted by sonoma
For anybody that cares, reinstalling w2k, catalyst 2.5, mmc 7.7, fixed the problem. ACPI put nic, sound, raid, video, etc on IRQ 11, and it all seems to work fine.
I need to correct audio drift
By Djard in forum AudioReplies: 13Last Post: 30th Jan 2012, 18:32 -
[Sloved] Hauppauge WinTV PVR-150 capturing using off air cable plug
By Wizard23 in forum Capturing and VCRReplies: 4Last Post: 11th Feb 2011, 22:07 -
Can VirtualDub correct audio drift?
By Djard in forum EditingReplies: 9Last Post: 26th Oct 2009, 19:33 -
AME CS4 Audio drift but not in others?
By x2x3x2 in forum Video ConversionReplies: 2Last Post: 15th Jun 2009, 19:27 -
capturing using different compters for A/V = mux drift/sync issues
By drstrust in forum Capturing and VCRReplies: 4Last Post: 17th Nov 2007, 09:13
