whats this????? can i fix this prob with using other softwares (Other Than TMPGEnc) ?
Aaliyah Is One In A Million,
She Sings On And On And On
She Gives Me A Really Good Feeling,
All Day long.......
Aaliyah Dana Hauhgton
- REST IN PEACE -
1979 - 2001 -
I assume you are making a vcd with Ez CD Creator. The problem is that your vcd is not multiplexed correctly. Yes you will need to use TMPGenc, but not how you think. File/simple demulitplex. Load your mpg and hit start. You will get an m1v (video) and an mp2 (audio.) Then go to file/simple multiplex. For the video section load this m1v and for the audio section load the mp2. For output set it to mpeg1 VCD and then hit start. When its finished load this mpg back in Ez Cd creator and it should accept it fine.
The best advice I can give you though is to stop using Ez Cd Creator. It is the most worthless vcd authoring software I have ever seen. You should try VcdEasy instead. Not only is it much better, but its free as well.
FAVC Error: Reference to non-existant scene
By major4579 in forum Authoring (DVD)Replies: 4Last Post: 7th Jan 2012, 08:33 -
HCbatchGUI System Error. Code: 2.
By lemmele in forum Video ConversionReplies: 0Last Post: 14th Sep 2011, 12:13 -
SupportPlus media player system file error
By Techophobe in forum Newbie / General discussionsReplies: 1Last Post: 16th Jul 2009, 07:01 -
reference Windows Media Encoder library error
By George2 in forum Newbie / General discussionsReplies: 0Last Post: 15th May 2009, 05:44 -
System.UnauthorizedAccessException error after WinXP SP3 install
By scoop46 in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 20th Oct 2008, 09:03
